hp2 calipers vs b5 rs4 calipers
  • K7ERG
    • 1711
    First off do the b5 rs4 calipers fit the hp2 struts without modifications?
    Are the rs4 calipers better?
    I have a set of 360x34mm discs new would I be able to uses with rs4 calipers?
    Pad price for the rs4 vs the hp2 caliper 4pads per caliper.
    thanks in advance.
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • prj
    • Mar 2010
    • 6308
    Don't fit B5 calipers, use B7 if anything.
    The B5 RS4 discs are crazy expensive if you compare them with other possibilities.
    • K7ERG
      • 1711
      I have discs that should be ok. looking at buying new hp2 calipers. just trying to see what my best option for disc and pad combo.314 discs around 100 to 120. Pads are around 150 to 180. Calipers are around 60 each. I have around 400 max to spend.
      B5 calipers are fairly cheap.
      I have 360 x 34 discs for any other suggestions.
      07947385043
