i have a set of porsche 944 brake calipers will they fit my s2 and wot disc size will i need and will the brakets fit the 944 caliper
porsche brakes
Originally posted by wigan11i have a set of porsche 944 brake calipers will they fit my s2 and wot disc size will i need and will the brakets fit the 944 caliper
The poor ones are the same as a VW golf and the good ones are nice alloy 4 pots which are ok.
David
Originally posted by Stick InsectWhich model caliper are they and which model and year car are they off?
David
sorry they r of 91-94 911 4pot can u tell me what size of disc will i need
Originally posted by wigan11sorry they r of 91-94 911 4pot can u tell me what size of disc will i need
Anyway if they are black or silver the original disk size would probably have been 304mm x 32mm.
If they are red and really huge they could be off the 993 TT ( twin turbo) and the disk size is 323mm x 32mm IIRC.
If they are off the late 944 / 944 turbo they the first size applies 304mm.
disks to use are 314mm Audi A8 disks machined down to 304mm £30ish each from Audi or GSF.
323mm S8 disks can be used as is.
You will need RS2 adapter brackets or the Seat Cupra RS brackets. and suitable nuts and bolts.
HTH
David
