What I thought was a winter wheel needing balancing appears to be a little more serious! I was shocked to see the inside face of the drivers side brake disc!
The outside is fine, showing little wear and there’s a good half an inch on the pads (I’ve got 996 monoblocks on so this is an A8 314x32mm rotor) Not had a chance to investigate yet and get the disc off, but I’m assuming that the inside pad must be stuck for the disc to get in this condition??!! Never seen anything like this before!!
cheers
Paul
cheers
Paul
Guess its not a good idea to drive around with the disc in that state!
