Hi guys are the S2 brakes plug and play for the mk 1 golf ?
S2 calipers
Sort of, you need Corrado or Passat G60 discs to make it plug and play, also I seem to remember the discs need to be turned down too 276 from 280 mm.
I'm fitting some to my MK II 16V, that will not be plug and play as I want them under 14" rims. It can be done
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
Will let you know
, I'm using ET 33 14" RM's which helps with clearance. Going to mean using custom Brackets and turned down disc's though.
1994 MTM RS2.
2000 B5 TQS.Comment
You may have a point there regarding the MK I Golf, I've got all sorts of callipers and carriers sat my shelf's, I'll take some measurements over weekend and report back.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
