I am approaching to time that i need to get the brake system done on my b2 cq.
Do not what way to go for.Dual pump braking or stock pump with servo,vacuum done by a reservoir/electric pump/diesel vacuum pump mounted in the cyl head.
What experience do you have with 2 pump brakes?How does it feel?How can it be adjusted?It is needed a compleete pedal listem or only 2 pumps bring together with a rod and in middle the car brake pedal atachement.
How is called this system?I googled dual pump/2 pumps etc,nothing found about it.
Maybe you can help with some rally aprooved lines mounted inside the car..
Regards
Regards
