brakes question
  • audinut
    • Jul 2009
    • 2195
    brakes question
    will a 996 351 425 caliper fit on a porcshe fitted with a 996 351 429 caliper?
    NOT a car dealer! just an S2/RS2 enthusiast
    Hell no
    • audinut
      • Jul 2009
      • 2195
      hmm whats the difference as the porsche in question originally had a 996 351 425 caliper on it but has been upgraded to the turbo caliper(but the porsche isnt running a caliper adapter etc) is it just the disc difference?
        Different mounting points, bigger discs, wider discs, different pads
        429 is GT3 MKI or 996 TT calipers
        425 is Porsche Boxster
        • audinut
          • Jul 2009
          • 2195
          so how can the 911 i have up the yard be running the 429 caliper with no adapter?
            Simple fact they aren't
            Maybe take this over to a porche forum and ask
              Pics of calipers http://www.s2forum.com/forum/showthread.php?t=43795
              • blues n 2s
                • Jun 2008
                • 136
                sorry to jump in here guys but can they (429/430) be used as an upgrade on front??still use a8 discs?? cheers
                I must have an S2!!!!
                • audinut
                  • Jul 2009
                  • 2195
                  yes vrs sell the adapter , and you can use the larger a8 armored disc 324mm i think
                    Yes but you are better using the merc disc as the A8 disc is 30mm width and the merc is 32mm or 34mm can't remember which. w429 were designed to used with a wider disc than 30mm
                    In saying that Bambridge and VRS have off the shelf brackets I think for the A8 disc so that does make it easier there.
                    • audinut
                      • Jul 2009
                      • 2195
                      Thanks jamo , it really is only just a question... even from the picture (to me the turbo caliper looks like it has the same mounting points as the non turbo caliper) yes its definately bigger i totally agree there.
                      Maybe the porka has had the hub changed ? (i dont really want to go to a porsche forum i just wanted to know if it was worth nicking those brakes and trying to fit it with the others )
                      • audinut
                        • Jul 2009
                        • 2195
                        bambridge doesnt have brackets for the 429's only will at vrs
                          Well that's not strictly true as Bambridge makes them for VRS, it maybe though thinking about it be that VRS owns the bracket mount drawings
                          • audinut
                            • Jul 2009
                            • 2195
                            lol trust me I pm'd bambridge today as i desperatly trying to sort out a brake upgrade ! hence the thread
                            • bambridge
                              • May 2009
                              • 609
                              As i said in the PM, if they are 429/430 brackets contact Will@VRS, i spoke with him a week ago and he still has some in stock
