I have to get new pads and rotor for my RS2 standard set up and is looking Porsche part replacement due to lower cost and wider selection. After reading across a few forums, I couldn't find a certain answer with cross references. This is what I gathered and would like to see if anyone can confirm these part numbers.
Front pads, if 993-351-939-01 does fit into an RS2, does that mean I can use any pads that say they fit a regular 993 ?
Front rotor, the part 965-351-041-01 seems to be quite hard to find. Is there any other parts that fit ?
Front - 304x32mm
Front Rotor - 8A0615301B(L) 8A0615302B(R) [ 965-351-041-01(Mono) 965-351-042-01 (Drilled) ]
Pad Damper - 8A0615231D x4
Front Pad - 8A0698151F [ 993-351-939-01 ]
Repair Kit - 8A0698430, 8A0698430A
Rear - 299x24mm
Rear Rotor - 8A0615601C(L/R) [965-351-041-01(Mono) 965-351-042-01 (Drilled) ]
Pad Damper - 8A0615231B x4
Rear Pad - 8A0698451A [965-352-939-04]
Repair Kit - 8A06986308, A0698630A
Front - 304x32mm
Rear - 299x24mm
