Now I'm only a two wheel drive guy and this is in reference to the rear brakes.
Anyway have changed the rear brake discs and have fitted a new ring to the disc, OE ABS ring on Pagid discs which has been pressed on.
Now when I've fitted it back up to the right "feel" on the bearing there is deffinate interference on the ABS sensor, looking at the old setup you can see that there is light rubbing as there is a clean ring through the corrosion.
So the question is should the sensor actually touch it, if not what gap should be maintained.
Hope someone has the answer before I get it rolling.
