Ok I thought it might be useful to have a thread based on two-piece brake discs, using rotors & alloy bells.
I'm designing some custom bells for myself right now for use with separate rotors, really to reduce unsprung weight Vs a large single piece disc, but also to give some flexibility with disc offset / caliper fitment across different rotor sizes, to enable me to run larger discs on track simply by using a radial spacer on my existing caliper bracket.
So in terms of bells, not being a professional engineer or designer I have selected 7075 as a possible material, at 12mm thickness - what are the experts thoughts on this.... Driftin Jo et al?
In terms of rotors, I was looking to use a common lug hole PCD if possible to give more flexibility, but struggling to find any information on anything other than AP discs - who else makes good quality rotors? i.e. not compbrake *****
AP
Alcon
Bembo?
Alex
AP
Alcon
Bembo?
Alex
