I have a short question. I want to change my front brake pads. what is the best way to do this?. Loosen the 2 number 17 nuts or the the smaller ones, 13 I think?.
thanks,
Erik
Getting everything sorted out for my 5++ hp project
When i changed my pads i removed the 2 caliper carrier bolts, move the caliper out the way, bin old pads, compress caliper with a pair of swan neck pliers with the cap off the fluid resevoir, then put it back together again
cant remember what sizes they were tho, was last year i done them.
Ant
2011 Kawasaki Z1000
Undo the lower 13mm bolt. Swing the caliper up and remove the pads. Push the pistons on the caliper out and close the caliper again and secure with a new 13mm guide pin bolt
