ahhh The 'bell' is the bit that is missing and that is the disc.
322X32mm disks where do i bay them??
Hi,
I would guess that are Porsche 993tt discs. I believe they are two piece.
I have heard that people like Movit use a special (expensive!) disc. The porsche 993tt disc is 323x32 which is close enough to the measurement you gave. Whats 1mm between listers!
Check that out.Comment
I can comfirm that 993tt are 322x32mm two part drilled,they are around £ 150 fromOriginally posted by twoquHi,
Check that out.
http://www.design911.co.uk/
______
Robsigpic_________
RobComment
HiOriginally posted by zloboi am only looking for the disk cause i got the rotors.. so if it's with a 5x130 rotor i can remove it and put my rotors on them.
Can you tel me if they meed to be balanced after attached the "hub" or "hat" whatever we cal...
I am about to need to change my front 322x22 to...Comment
