Brake caliper casting numbers
  • Colesy
    • Feb 2009
    • 2980
    Does anyone know whether calipers with the same casting number are always the same?
    Or are different calipers built using parts with the same cast number?
    I've got a brake caliper which has a casting number but no part number so just trying to identify it.
  • europeanme
    • Oct 2005
    • 3817
    there is normally, depending on the manufacturer, have the vehicle number, followed by the specific caliper range and then a left and right handed number to give the handed version. Have a search through the forum for part numbers for calipers, it has been discussed a few times now
    do you have any idea where they have come from?...
    • Colesy
      • Feb 2009
      • 2980
      Well, it has the casting number 3232 2393 which ties in with several models, I've found reference to it on a website that shows that it is the same casting number as several models including:
      An S6: http://www.brakepartssuperstore.org....-uk/d4881.html
      S4: http://www.brakepartssuperstore.org....-uk/d4872.html
      Audi 200: http://www.brakepartssuperstore.org....-uk/d4423.html
      Audi 100: http://www.brakepartssuperstore.org....-uk/d4378.html
      There aren't any other distinguishing marks so the casting number is all I have to go by.
      Thanks for the help.
      I'm just concerned that there might be slight differences between calipers with the same casting numbers?
      • twoqu
        • Sep 2003
        • 3103
        As it sounds like a rear caliper the piston size is also usually on the caliper. Look between the bleed nipple and the handbrake lever, it should be in a recess there. If its 41 43 then its most likely a Ur 20V/V8/Ur S4/6 rear! If the handbrake bracket is bolted on its an A8 version!
        The reason it appears as 100/200 is that it was a very rare option for those models. The 200 20V would also have that caliper but we never got that over here in RHD at least!
