Hey guys, been a long time lurker, but figure id finally post away.
I've been wondering if anyone has tried retrofitting a D2 A8 rear caliper onto a UrS6. The reason for this would be to run a slightly bigger pad as I figured out how to run a 300mm b6 S4 rotor.
I already have everything ready though instead of using my stock rears, which are seized, id like to use the D2 A8 calipers as they have bigger teeth to encompass a bigger pad. They have the similar style hand brake cable setup, though I'm wondering if the brake lines and if the actual brake cable is similar or the same.
Any info / suggestions would be greatly appreciated.
