Quick question, could the 996 rear calipers be used on the s2?? The codes for these calipers are 996.352.421 and 996.352.422
Possible to put on the front?? If so what would be needed
Probably not worth it, they have smaller pistons than the 996.351.425 & 426 setup and you'd probably need custom mounts, not sure what size discs they would take, might not fit the A8 323mm discs so discs would be a problem too. So with all the extra hassle it makes most sense to just stick with the tried and tested setup.
