Brakes anyone had this problem ?
  • jade
    • Jan 2005
    • 1811
    Anyone had this ?
    When braking from speed my steering starts to wobble, I can also hear my hydralic pump working over time, I have changed the pump a while back problem went away for a few weeks then came back
    I have never heard of anyone else with this problem seem strange the second pump should fail in the same way
    Any feed back well come
    RS 2 580HP
  • Rusty
    • 18953
    Wobble is discs. Pump noise could be failing servo - feels like ABS kicking in.
    • jade
      • Jan 2005
      • 1811
      No wobble is not discs
      Pump noise the hard and longer the braking period the more the noise, this is high speed braking
      Not sure about servo as braking power feels ok, but I am wonder why the pump is working so hard
      The steering wobble is related to to the pump working over time as the rack and brakes are powered from the same pump
      RS 2 580HP
      • fish
        • Aug 2007
        • 2333
        • Home: United Kingdom Current: Sweden
        Wobble can also be caused by sticking/seizing calipers.
        Audi 80 Competition -94 Daily driver
        www.garaget.org/fish for more pic´s of my cars
        • jade
          • Jan 2005
          • 1811
          Rebuilt callipers, new discs
          This problem started a while back first thought it was the discs changed them
          Then rebuilt callipers
          Balanced wheels
          Then reviewed it all two more times, then started looking else where
          As stated in earlier posts changed pump problem went away only to return
          Under hard braking he pump makes a loud whiring noise as if it is working over time, this is the second pump i have tried it was working fine on the car it came from
          RS 2 580HP
          • europeanme
            • Oct 2005
            • 3817
            are the discs seated on the hub 100%?.....
            are you running standard brakes?
            • sam80quattro
              • Oct 2006
              • 1496
              is the pump powered by the power steering pump or am i thinking of something else? if so could you not remove the belt and try the brakes, obviously i realise there will be no assistance but surely it will rule out warped discs, badly seated etc etc
              • jade
                • Jan 2005
                • 1811
                The problem has nothing to do with discs, hubbs, wheels all these thing have been rule out long ago
                it related to the hydralic system, steering pump, servo or booster but i am wondering what could cause the pump to fail so Quickly again and why it is running under so much load
                when the the brakes are load up i start to get feed back through the steering coming from the pump
                RS 2 580HP
                • willg54
                  • Jun 2009
                  • 2055
                  Surely this must be bomb related if powersteering is affecting the brakes?
                  I know you say you've checked the discs etc but have you run a clock on them to check?
                  Sent from my GT-I9300 using Tapatalk 2
                  • driftin jo
                    • Sep 2007
                    • 2222
                    Its your bomb as it should have enough reseve
                    Pressure For braking many times after a belt snaps.
                    • jade
                      • Jan 2005
                      • 1811
                      I have to sets of discs both have been on the lath twice all faces checked
                      The bomb is quite new it came from autocraft but maybe that could be where the problem is
                      Thanks for the feedback, I will try a new bomb
                      RS 2 580HP
                      • willg54
                        • Jun 2009
                        • 2055
                        If you search recent posts you'll find I had brake wobble recently.
                        My discs had been reskimmed. When I measured them on the car, one had about 2mm of run out but of course could have clocked perfectly on a lathe. New discs...problem solved. Cheapest and easiest thing to try!
                        Is the vibration quite violent at high speed and slows down with speed?
                        • willg54
                          • Jun 2009
                          • 2055
                          It would also give you the feedback you're experiencing in the pedal
