996.351.429/430 contact me I need help
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    If you have these Porsche Caliper part numbers 996.351.429/430 fitted to your S2 ABY please contact me.
    If you have 34 thick discs fitted as well then please contact me or post the part number. If you have less than 34 please post the part number.
    If you have a bracket to suit the above with the 34mm disc or a 32mm disc then please contact me.
    If you have a drawing of a bracket with dimension then please share it with me.
    Thanks
    orsum
  • europeanme
    • Oct 2005
    • 3817
    try will20v on here...he makes the brackets...
    the front discs should be on a sticky somewhere in the brake area...S8 discs....323 x 34mm..
    HTH
    Mike
    • orsum
      • May 2010
      • 1213
      Hi europeanme,
      The S8 is a 32mm and will20v is not answering my call for help PM sent to him but no reply. Which S8 disc is also a problem there are quite a few different part numbers available.
      I have been through every sticky but still confused about the discs to use and I cannot find the bracket drawing or contact will20v.
      Thanks anyway.
      orsum
      • europeanme
        • Oct 2005
        • 3817
        what size wheels are you running?
        • orsum
          • May 2010
          • 1213
          Presently using the the standard rims, when I manage to fit the calipers I have a set of Audi B7 S4 18" rims waiting to be put on.
          orsum
          • europeanme
            • Oct 2005
            • 3817
            4E0615301P might fit....not sure about brackets....I know Will is very, very busy...
            • orsum
              • May 2010
              • 1213
              Thanks for the help I am sure he will respond.
              Also found this
              UK specialist supplier of car brake discs, pads, calipers & HEL braided hoses. Quality OE brake parts from top brands like Mintex & Brembo.
              BDS6118
              £136.08
              Weight: 28.00 kg
              2 Brake Discs
              Qty 2
              Disc Type Vented
              Mountings 5
              Disc Diameter 360.0
              Disc Thickness 34.0
              Overall Height 59.6
              Hub Hole (Diameter) 68.0
              orsum
              • Big Lee M
                • 2571
                They are a bigger caliper to what everyone else normally uses, are they the Porsche Turbo calipers you have?
                Just some finishing touches to do now
                • orsum
                  • May 2010
                  • 1213
                  Yep the type I have are known as Big Reds Porsche 996 GT3
                  996.351.429
                  996.351.430
                  Normal type used Little Reds
                  996.351.425.(11)
                  996.351.426.(11)
                  orsum
                  • europeanme
                    • Oct 2005
                    • 3817
                    mine are 996.351.431 & 432 - 6 pot GT3/2's
                    can you get things machined in SA?
                    • europeanme
                      • Oct 2005
                      • 3817
                      • orsum
                        • May 2010
                        • 1213
                        Yes we have some very very good machine shops.
                        I have one were I work
                        orsum
                        • orsum
                          • May 2010
                          • 1213
                          They are very big what you stopping with them? lol
                          So what are they called 996.351.431 & 432 - 6 pot GT3/2's also know as
                          Very Big Reds?
                          orsum
                          • Drummer87
                            • Oct 2009
                            • 1644
                            • Home: United Kingdom Current: Scotland
                            Don't you need the rs2 bracket for them?? Saw some on vrs eBay few weeks back
                            • Drummer87
                              • Oct 2009
                              • 1644
                              My bad ignore me
