UFO to hp2- which hoses needed?
  • bluequattro
    • 2960
    Ok, have complete struts with calipers etc
    Do UFO hoses fit ?
    I need to know so I can order new ones
  • merlin's S4
    • Jan 2005
    • 1539
    They might do! Or else just buy the later hoses from an S6 or late S4. Maybe you could check part numbers between the two.
    • mcandmar
      • Apr 2004
      • 5118
      I'm about to do the conversion myself, hopefully this weekend. From looking at the parts system the rubber flexi hose is the same, as is the metal bracket on the caliper it connects to but i will confirm for sure when i have mine done.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • bluequattro
        • 2960
        Great info!
        Mcandmar can you pm me when you ve done with any surprise pitfalls please!
        • mcandmar
          • Apr 2004
          • 5118
          Conversion done, really is plug and play. The flexible brake line, metal bracket bolted to the caliper, and the metal hard line are identical so i took them off the old UFO caliper and everything bolted up perfectly
          Only subtle difference i noticed is the small brackets on the strut to hold the pad wear and abs sensor looms, on the S4 they are held on with 8mm bolts, on the S6 they use 10mm bolts. I was missing a few so i had to drill the holes out to fit them onto the S6 strut. But apart from that everything else is identical.
          • bluequattro
            • 2960
            Great info, many thanks
