Bit of a strange one this, well, it is to me at any rate.
The car was showing symptoms of a sticking front left brake, i.e., very hot disc compared to the right hands side and increased pad wear on the inner brake pad.
I'll cut a lengthy story short to say that I rebuilt the nearside caliper using new seals and bled the caliper without to much trouble.
I put the wheels back on with the car still raised on axle stands. I started the car and selected first gear. The left wheel can be seen running freely now but the right wheel is sticking.
The right wheel can be turned by hand but with more resistance than the left.
Any idea why this should happen and what I need to do to fix it?
Thanks in advance,
Rob.
Thanks in advance,
Rob.
