v6 master cylinder
  • chunkymunkey003
    • May 2009
    • 7
    v6 master cylinder
    Hi, sorry for the noob question but I'm a Golf man.
    I'm looking to upgrade my master cylinder for a v6 version that's 23,81mm, part number 894 611 021.
    Does anyone know if they were on another model coupe's?
    Matt
  • shaun5
    • 1610
    If its a master cylinder from a v6 model you are after then i would think one from a saloon, estate, coupe, cabriolet will fit
    I have broken a v6 saloon so got one you can have
    • mcandmar
      • Apr 2004
      • 5118
      That part number seems to fit 4cyl and 6cyl 80 saloon and avant, and v6 engine coupes.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • chunkymunkey003
        • May 2009
        • 7
        Thanks a lot, I've also been told now the 20vT master cylinder might be a possibility, P/N 441 611 021 B - 25,40mm, have any of you got one or a pic?
        Thinking this might be an even better upgrade as that should match my S2 calipers as designed lol
        • shaun5
          • 1610
          Ive got one from a 90 20v (which uses the G60 front brakes, same as S2) which i know is in working condition and ive also got on from a 93 S2 estate, its been of the car for some time but all the ports are covered so it should be fine.
          I dont have the part numbers for them as they are at my parents but they should be what you are after
          • chunkymunkey003
            • May 2009
            • 7
            sounds great Shaun! How much we talking?
            could you get pics and part numbers sometime? there's no huge rush, I'll pm my mobile number too, thanks
