Goodridge hoses for monoblocks -Opinions
  • re2500
    • May 2007
    • 2185
    My front brake hoses are cobbled together using various braided hoses off other cars, its functional but far from ideal, i'd like to get some 1 piece ones made. And my rears are getting crusty so will replace those too, they arent an issue as i could use standard goodridge spec for the rears.
    Ive trawled quite a few threads on here to find info on lengths and fittings for creating a goodridge one piece flexi hose for use with front 996 calipers.
    I intend to get some made by Merlin on the weekend, so want to get the info ready for then.
    I found this post with a drawing for an 800mm hose:
    Is this the optimum solution for a one piece hose? Anybody got any improvements on this? End fittings, hose length, fittings for securing the hose etc...
    Thanks in advance
    "Difficult is worth doing"
  • re2500
    • May 2007
    • 2185
    Bttt
    • johne
      • Apr 2007
      • 1405
      This is what I have, a one piece Goodridge hose from the inner wing to the caliper and it's been good with no problems.
      I kept the brake hose joining bracket on the back of the strut and used it to pass the Goodridge hose though with a short length of 3/8th rubber hose around the outside of the hose to protect it from any sharp edge on the bracket.
      Can't recall the length of my Goodridge hose - which I had custom made by them - but I could measure it if you like.
      John
      • targus
        • Sep 2012
        • 185
        • Home: United States Current: England
        I'd be interested in knowing the length of the hose needed plus the fittings as I need to order some.
        If merlin make them up for you re2500 can you let us know what the price is
        • Colesy
          • Feb 2009
          • 2981
          When you get lines made up try to get circlip type fittings on the chassis end else securely fitting them might be an issue as per:
          I ended up using a OEM Porsche hoses and hardlines on the front.
          • re2500
            • May 2007
            • 2185
            Cheers guys! So 800 mm and a circlip female m10x1 fitting. Is the other end fitting correct? Or am I better off with a straight male fitting into the Caliper?
            • Colesy
              • Feb 2009
              • 2981
              I'd say definitely stick with the 90 degree bend.
              • re2500
                • May 2007
                • 2185
                Ok cheers bud!
