tuareg 330mm brake calipers on s6 c4
  • ADP
    • Mar 2011
    • 200
    • Home: Bulgaria
    is it fit,and what kind of rotors!?rear brake calipers from rs6 c5,will fit on s6 c4? many thanks!
    Have you any more details on the calipers you have. there are some tried and tested brake conversions well documented on the forum which may be more straightforward for you.
    • ADP
      • Mar 2011
      • 200
      • Home: Bulgaria
      yes,the callipers are 17z!i try and they fit perfect on the s6 hub!so i need some advices about rotors!?if you please!thanks in advance!
        Interested also in what rotors might work, especially so if the 17z calipers bolt straight on ?
        Thanks.
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          I think 18Zr is much more easier to make it fitted.I use 360mm from 2006 A8 rotors with resized them down to 354mm.it also need to get the
          brake pads from 17ZR due to the narrower sliding face on the rotor from being resized down the rotors diameter.
          one of a few I5 from Asia.
          • ADP
            • Mar 2011
            • 200
            • Home: Bulgaria
            So mates the rear calipers from rs6 c5 are here, and they are in great condition!i will try to fit them!
            • rs200
              • May 2009
              • 1398
              • Home: Croatia
              use 345 mm disk from s8 but your wheel must be ET 25
