no way Dom, thats from a Cabriolet!! and at that only up to 1992!! no way sir.
OK Thanks Martyn
Looks like I am going to have to stump up for the other one and then Knock the cost of it off what I owe him
I am sure he will be over the moon about that But he gets a reasonable amount of work off me and I always settle up in cash straight away, so I think he can wear his own *ukup this time
Going down there later to pull the sensors and clean them up and a couple of other bits, so if that doesnt cure it then I shall order the ECU.
Problem is, an Hours Labour at the Audi Stealers to check the fault codes is about the same as the ECU cost, they may end up telling me I need the ECU as well and its then doubled in Cost IYSWIM ?
