handbrake cable change on A6 quattro
  • K7ERG
    • 1711
    I was thinking of doing this myself in the drive but being Quattro should I just get a garage to do it?
    Opinion welcome
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
    Originally posted by K7ERG
    I was thinking of doing this myself in the drive but being Quattro should I just get a garage to do it? Opinion welcome
    Depends how big your hands and wallet are. Big hands and big wallet = garage, small hands and small wallet = DIY
    Here are some hints and info (watch for the the rear brake DIY link):
    • bluequattro
      • 2960
      If only I'd found that guide before doing mine
      An hour passenger side to learn it n get off rounded bolts, 15 minutes drivers side!
      Rubber boots on sliders needed replacing, didn't come with new calipers and so stealers r*ped me for £23 for 4 boots, no local suppliers would/could supply in their own
      • andy10v
        • 5996
        Opinion welcome
        If you have a spare hour it should be straightforward. Same as usual stuff may be seized though.
        Jack, axle stands, socket set, flat screwdriver, deep socket for the adjustment nut.
        Roughly
        Jack up
        rr wheels off
        remove the heatsheild above the exhaust/prop to access the handbrake yoke
        slacken adjuster nut (you may be able to lever it out the caliper without but it makes life easy)
        unhook cables
        remove handbrake cable clip from caliper
        lever handbrake cam
        remove cable from caliper
        remove cable from clips under the car
        Fit new cables and adjust handbrake to taste, I prefer a bit more movement as less prone to seizing.
        Sold ABY-stock
