S6C4 Hydraulic to Brake Booster conversion
  • kotnelson
    • Oct 2008
    • 48
    • Country: Thailand
    I see the thread of conversion on other model but not with S6C4.
    I have done the brake assist from Hydraulic to Vacuum assist sometimes ago, hope this info could be useful. Apologize if duplicate thread.
    Part require
    - Brake booster from A6C4
    4A0611021E tandem master cylinder id 23,81mm (15/16")
    Engine ACE,ABC,ACZ, AAH,AEJ
    (While the stock was id 25,4mm (1"))
    ***Some of those brake booster already has 1 way valve, some not***
    - 048145155FX vane type pump / power steering
    ZF / AAR,AAN
    Since the stock was not in good condition, I got replacement from Audi 100C4 AAR
    which does not have the high pressure line to accumulator, cut me short not to mod
    and plug the stock one.
    - 1 way valve (I used one from local shop, with ball or Cylindrical valve, avoid flat rubber valve)
    - Fuel hose 3/8" approx 1000 mm
    - Clamp for fuel hose (to avoid damage to fuel hose if use other type clamp)
    - 3 way brass pipe 1/2" and reduce to 3/8" (find the suitable set)
  • kotnelson
    • Oct 2008
    • 48
    • Country: Thailand
    Remove this bar
    Remove everything in this picture, except #26
    #26 is return line from power steering.
    Plug out, block, #14 and #15 (Red circle)
    Install Brake booster, you need the old........
    4A0611301E expansion tank lhd / AAN,ABH
    4A0611301G expansion tank rhd / AAN
    as the cap position.....
    • kotnelson
      • Oct 2008
      • 48
      • Country: Thailand
      - Install vane type pump / power steering, connect feed line and high pressure line to steering.
      - install brass pipe between ISV and IM
      - run fuel hose to brake booster, if booster already has 1 way valve.
      if not put 1 way valve in between this line.
      - to have a better vacuum, you may add a reservier tank as this pic, another 1 way valve between IM to reservior must be added.
      • kotnelson
        • Oct 2008
        • 48
        • Country: Thailand
        Brake bleeding.
        Test
        - Start the engine, idle for a minute. Press brake and feel the paddle.
        - Idle for 1 minute and turn off
        - Press brake and count, you should have about 2-3 time before it is very hard
        - Keep pressing brake paddle, start engine. Brake paddle should move down
        - Leak test, using soap solution or else, or use Boost test technique
        Finish and off you go.
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          Parts added,it requires the clevis from A6/100 model.the hydro system clevis is different(smaller).
          one of a few I5 from Asia.
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            I forget another parts.you also need the o-ring between the mc and the booster for vacuum booster since after done the conversion.it became the closed system.
            • caterpillar
              • 2480
              and the reason for doing like this; big trouble with the hydraulic brake asist or??? nice pics and idee .. but why?
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                Hydro system is cost a fortune.
                • caterpillar
                  • 2480
                  thats correckt
                  • kotnelson
                    • Oct 2008
                    • 48
                    • Country: Thailand
                    Yes, if use the stock MC 1" with new vacuum booster.
                    Without new o-ring, you will have a vacuum leak.
