cold weather-brake sign beeps
  • horvathg
    • Dec 2003
    • 556
    Whats this? The red brake signal with 3 beeps and 6 blinks has been on for a year but now as it is around 0 degrees it stays on for all the time when driving in town. Actually, it may cease when I hit the brake pedal heavily but then its on again. Bomb? Or what? Have you experienced these things yet?
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
  • horvathg
    • Dec 2003
    • 556
    Any ideas please? A rather annoying thing this is if you want to know. Fluid levels are OK. Brake pedal feeling is rather soft at the bottom though...
    Gabor
      Dead bomb - or faulty brake servo - or PAS not pumping properly.
      Hydarulic fluid correct (G2000) and at right level ?
      Paul
      • porkkis
        • 1994
        Or faulty sensor but I'd say it's probably the pump that is tired and can't make anything of the cold oil.
        • horvathg
          • Dec 2003
          • 556
          Thank you very much for the enlightening good news.
          Gabor
