I am replaceing both handbrke cables on my 3b. Has anyone btdt I would appreciate any advise on the best way to go about this. is it easier to undo the prop or not.
advice on coupe handbrake cable replacement
Some info and links/how to in this thread
Phil Paynes link has the method for adjusting the handbrake.
You can do it with the prop in situ, it might help to remove the heatshield to see what you are doing if you have not done it before.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
