S4 Bi-turbo callipers
  • Graham
    • 1622
    Will the rear callipers off a 2000 Audi S4 Biturbo (type 8D) go straight on my car without the need to replace the discs. My callipers are U/S and i dont like the look of £150+quid to sort them and i have found a set on flea bay. With 2 days left
  • Doug_RS2
    • 3847
    Graham - These are what can be used for a rear brake upgrade, with machined vented discs and different brackets - I was going to bid on them but won't if you are going to?
    I know someone who has the solid rear brakes and calipers off an S4 if you are interested in them?
    • Graham
      • 1622
      If they are a straight fit and the handbrake works i am definitely interested (Mam said i can have anything for X-mas as our lass wont buy me anything for the car), also if i have to change the discs i wont bid on the S4 setup -good luck i hope you get them.
