Monoblocks on rear of RS2
  • twenty valve
    • Oct 2010
    • 630
    Has anyone fitted monoblocks to the rear of an RS2?
    Calipers Pn's : 996 352 425 20 722401 ABD 996 352 426 20 7224 02
    Looks like you'd need to use a Porsche disc (911 or whatever) as the pad area is way too big for the stock RS2 disc. My only concern is whether the handbrake shoe diameter and offset is the same... I seem to remember MRC doing brackets for this conversion but this can't have been for stock disc
  • will20v
    • May 2007
    • 391
    i do the bracks so they fit straight to the original discs. calipers you need are 996352421/422
    cheeers
    • John B
      • Apr 2008
      • 926
      cheeers
      Will, are you sure?
      The brackets fit the coupe solution fine as documented http://www.s2forum.com/forum/showthread.php?t=62766
      I am fairly sure from the thread http://www.s2forum.com/forum/showthread.php?t=22558 that the S4 300x22 disc will suit the 996 rears with your adaptor for an S2 avant.....but for an RS2 with different hubs / half axles etc. will the adaptor fit?
      I don't have an avant or RS2 or access to them, so cannot measure up to be sure. Anyone?
      2001 996 C4 - Being renovated
