RS2 Rear Brembo caliper in S2 (ABY)
  • Guslotti
    • Mar 2011
    • 182
    • Home: Italy Current: Brazil
    Hi,
    someone here installed rear calipers from RS2 in a Audi S2 ABY? If yes please send me pictures and parts numbers!!!
    Thank you,
  • 5cylinderman
    • Oct 2011
    • 367
    From what I've read here on the forum the RS2 handbrake can be a troublesome SOB. Is this right, RS2 owners?
    • Henkjan
      • 1705
      yep, the RS2 has the Porsche setup, so with a handbrake drum in the hub... so you need to do a full conversion incl hubs, or use a separate handbrake caliper (see thread on that, 996 rears) or use a hydraulic handbrake (might not be legal)
      • John B
        • Apr 2008
        • 926
        Originally posted by Guslotti
        Hi,
        Thank you,
        I guess you have a coupe as you have mentioned it being an ABY. If so, have a look at http://www.s2forum.com/forum/showthread.php?t=62766
        these work on 996 rears not RS2 setup, which is quite different with an in-disc handbrake solution.
        JB
        2001 996 C4 - Being renovated
