Warning light
  • scouser_75
    • 306
    Originally posted by dog
    I did the bomb test i got 58 but i have the flashing light when i start the car only for a while and then it switches off. I checked the needle and thats fine, n e ideas?
    Could this possibly mean that the bomb is on the way out?
    • Fat Audi 80
      • 10547
      Do you get the beeps and flashing while driving.
      Whenever I have had those syptoms on mine, a quick fiddle with the connector for the level sensor on top of the green hydralic fluid resevoir has cured the warning immediately.
      Personally if you have well serviced brakes and your passes the stationary pedal pump bomb test I would not worry about an early morning beep or a beep if the car has been standing......
      Cheers,
      Steve.
      The Perfectionist
      • dog
        • 100
        Just beebs when u switch her on in the morning or been standing for a while,
        ON THE SEARCH FOR THE FOUR RINGS
        • S2 Ant
          • 3682
          Check and clean the connections on the resevoir as they may be dirty or corroded.
          Also make sure the cap and spring bit is in ok as ive had mine get caught at some dodgy angle before and it beeped, checked that and the connections and it was fine.
          58 pumps is good so bomb should be fine.
          Ant
          2011 Kawasaki Z1000
