Abs/brake Help
  • AquaS2
    • 705
    Abs/brake Help
    So Iv had the cv boots changed and upon return there's a grinding noise from the brake pedal along very poor braking. The pedal is as normal, not harder or softer. If you brake hard it will slow down slowly and after a split second the brakes will bite really hard. Almost like abs kicking in.
    Similar characteristics to a hose pipe that's got a kink in it and then suddenly opens up to allow fluid through.
    Abs light is not on.... In the meantime Iv pulled the abs fuse and all is well.
    Any ideas of what maybe the cause?
    Harry
    F I R E U P T H E Q U A T T R O
    1996 S2 coupe aqua green sold
    1990 MK2 Golf gti 16v oak green sold
  • Acidburn
    • 13459
    the grinding noise, is that actually inside by the pedal or is it more like a twanging noise?
    • benntenn67
      • Jun 2009
      • 859
      The abs sensor has been disturbed on the wheel/s you've worked on, had the same thing on my b5.5 passat years ago - refitted it & all was ok
      Audi S2 Coupe 1995
      VW Passat GL5 (hatch) 1986
      VW Passat GL 1.8 (saloon) 1986
      Carrera Subway 8
      • andy10v
        • 5996
        Sounds like disturbed sensor or damaged/clogged teeth on the cv joint.
        Sold ABY-stock
        • AquaS2
          • 705
          Can't say my ears are in tune to give you that answer but you can feel the pedal vibrating too.
          • AquaS2
            • 705
            If the sensor is disturbed would that flag up the ABS light? As nothing comes up...
            • benntenn67
              • Jun 2009
              • 859
              No - not in all cases
              Audi S2 Coupe 1995
              Carrera Subway 8
              • AquaS2
                • 705
                All sorted, it was indeed a disturbed sensor
                Thanks chaps
