996 turbo disc options
  • 996 turbo disc options
    Im just after a bit of advice, not really sure if this is the best place to post this but here goes...
    I have just bought a set of 996 turbo callipers and i just wanted to know what options i have for the discs.
    Any info would be good..
    on s2 hubs..
      yes on s2 hubs sam
        i used the 323 ones from cam skills. very good and 90 quid delivered. pretty sure they are black diamond ones but not branded.
          thanks i will have a look at the website, do you know what thickness are they?
            Which 996 calipers are they 351 429/430 or 425/426 ?
            RS 2 580HP
              429/430 are the calipers blythey has
                Should be 330mm or plus with them and 32mm min but better 34mm discs
                RS 2 580HP
                  and 32 or 34mm thickness. 30mm is too thin really.
                    Ok thanks for the advice, does anyone know what discs people have used? Ie off which car?
                      Audi A8
                      BUT I DON'T WANT A NEW CAR!
                      1995 S2 Avant, Volcano Black
                        http://www.camskill.co.uk/m13b0s744p...e_discs_-_AUDI
                        I think prices have changed slightly.
                        Eric
                        95 S2 Avant under rebuild.
                          Don't bother with drilled or groved, no need for it.
                            are the turbo calipers not to big for 323x30? i suppose as long as pads are changed early enough the pistons won't pop out lol
                            • #15
                              Do you already have caliper mounting brackets ?
                              RS 2 580HP
