RS2 Caliper rebuild kit
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    Hello everybody,
    It is time to put some new brakes on my RS2. I got new brake rotors and pads but my calipers look pretty sh...y. Previous owner has sprayed rear calipers with some stupid red paint ( I suspect during bleeding they got some brake fluid over caliper spilled and damaged original coating). Anyways i found some good coating company close where i live here in Germany and i thought about letting my calipers re-coated. However then need to be taken apart before coating so that means I need at least new piston seal o-rings and dust covers, however when i went to stealer (as our British friends like ti say) i have learned that these rebuild kits are no longer available.
    Can anybody tell me where i can buy this stuff and how much they cost?
    Thanks in advance for all help
  • chezz
    • Apr 2007
    • 440
    Maybe Bigg Red provide a kit...look at the Porsche sites i.e. RS2 rears are 944 fronts so you should be able to get seals for the rears at least.
    • LGK6D
      • Oct 2011
      • 288
      Hi Chezz,
      Is that confirmed that's where the rear calipers are from, I've been wondering what they came from. I had it in mind they were 968CS M030 rear callipers?
      Many thanks
      David
      • chezz
        • Apr 2007
        • 440
