Came up today with an explanation of: right side inlet/outlet valve problem. Intermittent.
The ABS light comes on and off on its own but the code is stored. I can erase it, come up then the light will go off if I switch off the engine and restart the car.
I'm trying to understand if this is an ABS sensor issue or one of the internal valves of the actual ABS module
