Yellowstuff Pads
  • merlin's S4
    • Jan 2005
    • 1539
    Yellowstuff Pads
    Has anyone had any experience with EBC's Yellowstuff pads? I'm looking at some for my Cayenne calipers as they're similar in price to the standard Pagid pads.
  • Rusty
    • 18953
    Run them on my Clio and a mate runs them on a Golf track car, they're pretty good for the money, good from cold and bite well when hot. Need to be bedded in properly to work their best, as they have a bedding in coating that hac to wear off.
    • Sonic
      • Jul 2006
      • 5514
      I had a set on the rear, went through them very quickly indeed and put DS2500 back on.
      S2Forum.com Administrator
      • simesf
        • Feb 2009
        • 25
        • Home: England Current: France
        Hi
        I had redstuff reds on my rs2. Wore out through normal use (no track etc.) very quickly - 8000kms!! I wrote to the company never got any reply. Don't know what the yellows are like but I wouldn't touch them again!
        • Rusty
          • 18953
          Reds are a different thing entirely but are supposed to last a while
          Odd that the yellows have worn so fast, the Clio front brakes are still plenty thick at 13k miles.
          • stocious
            • Jul 2012
            • 838
            living in the Alps might be a factor in wear.
            1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
            • Rusty
              • 18953
              • simesf
                • Feb 2009
                • 25
                That's true!! But it was the Winter you can't brake that hard with snow on the ground The standard pads do around 25000kms!!
