need more brakes!!!!!
  • need more brakes!!!!!
    can anyone advise me about better brakes i want to stay on 16 inch avus wheels.Currently using zimmerman drilled and greenstuf pads 6/10
    May '95 Black S2 Avant, standard with K&N filter
    Search the forum for Porsche 996 calipers. My total cost was less than £450 for recon'd calipers, custom brackets, RS2 brake pipes, A8 discs, Textar pads.
    Now RS2'less
    '99 VW Passat VR5 Sport
      are these ok on 16s???
        http://www.slybadger.com/cars/s2/brakedetail.htm
        These are what Pete was running on his old Avant and what i have on my car from the previous owner.
          They do fit under 16" Avus wheels off the shelf like this but caliper to wheel clearance is minimal - probably less than 1mm. You're better off machining the disc down from 314mm to ~308mm to provide more clearance. This is what I did.
          Now RS2'less
            i have the idea that maybe i can use the disc from the a8 the caliper and bracket from a v6 4motion golf,does any body have the part number for the a8 disc/an old woren disc i could have,for testing my idea.
            when you can use the s2 caliper on the g60/ g3 vr6,then it must work the other way too.
            Regards
            RIX
              thanks guys
