Brake bomb replacement guide
Go Vacuum servo and save your self problems
brake and hydraulics are not connected so no need to fill unless neededRS 2 580HP -
Are you sure it's the bomb? Have you tried bathing/ leaving to soak the power steering cap/ sensor in cleaner and given it a really gentle brush with a soft brush? 99% of time that is what causes people's (!) symbol. I have had to do it a few times over the years as it gets a bit sticky for some reasonComment
Yep had tried the cap a few months ago, still was the same! It happened more noticeably in hot weather though (As we have now). Oh well replacing stuff is always a good thing right? (Not in my experience though as replacing the radiator meant replacing the A/C condenser, Compressor and A/C pipe
Tomorrow a few more goodies to get installed on the car, hopefully it won't have its mishaps
1996 S2 ABY SilverComment
I replace the bomb on my 3b . Well actually my brother who isn't really mechanically minded did.
He did it in an hour. 1 litre of fluid was enough and you don't have to touch the brake fluid.
Its not plumbed in.
I gather its easier on an aby as you don't have a battery in the way.
The good news is it was one of the best things i ever did. I was sick of the bleep after start up and hard braking followed by tin wife going. Why does it always do that!?Comment
Should be pretty easy then, they've had a hand at a fair bit of work on my S2 and never had any problems even though they'd never worked on one before, with a bit of guidance from the forum ofcourse
. They're more used to working on Kias and the likes of the crap we have these days
Will be up on a jack so access from underneath bonus
, got an RS2 FARB with RS2 drop links going on today as well as replacing a torn CV boot, fuel filter, that's it I think, really need to make a list of the things I replaced in the past year since I've owned my S2, quite a fair bit
