RS2 Brake Caliper Pad Sliders
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    Hello Friends,
    I was wondering if anybody had a part numbers for brake caliper brake sliders and screws that hold them in place for front and rear RS2 calipers?
    Note: I have 304mm front brake set up.
    Thanks in advance for all input
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    8A0698430 upper fronts stock disc 304mm
    8A0698430A lower fronts stock disc 304mm
    8A0698630 upper rears
    8A0698630A lower rears
    the part number it's for two of each type the list above gives you then a complete cover for the four calipers
    screws are coming inside the packaging
    Stefano
    http://www.audisportclub.com/
    • BosnianS2
      • Apr 2005
      • 322
      Thank you very much, now i can go order some parts and finaly get my brakes done . Should I order at Porsche or Audi dealer?
      • veneto rs2
        • Jun 2006
        • 1022
        • Country: Veneto
        You can't order in Porsche with those numbers.
        Anyway I just did my rears one and done a little research on the web and asked also at Porsche dealer.
        Eventually I got them from Audi because I have a good discount at my local dealer the difference it's minimal anyway as far as I remember.
        you should spend 100/120 euros for all of them.
        The parts are coming on Brembo packaging.....
        Stefano
        • BosnianS2
          • Apr 2005
          • 322
          Sounds like a plan. Thanks one more time
          • portzi
            • May 2011
            • 75
            hELLO, I HAVE JUST STRIPPED DOWN MY REAR CALIPERS , AND WANT TO DO THE FRONTS AND REPLACE THE STAINLESS STEEL CAGES THAT HOLD THE PAD IN PLACE, ARE THE ABOVE NUMBERS CORRECT FOR THE "LITTLE REDS ON THE RS2. WHERE TO GET THEM IN THE UK AS EURO CAR PARTS AND GSF DONT RECOGNISE THOSE PART NUMBERS
            REGARDS
            MARK
            • europeanme
              • Oct 2005
              • 3817
              Originally posted by portzi
              hELLO, I HAVE JUST STIPPED DOWN MY REAR CALIPERS , AND WANT TO DO THE FRONTS AND REPLACE THE STAINLESS STEEL CAGES THAT HOLD THE PAD IN PLACE, ARE THE ABOVE NUMBERS CORRECT FOR THE "LITTLE REDS ON THE RS2. WHERE TO GET THEM IN THE UK AS EURO CAR PARTS AND GSF DONT RECOGNISE THOSE PART NUMBERS
              REGARDS
              MARK
              what is the part number on the caliper (99*) number and I'll speak to a contact at Nottingham Porsche...
              Mike
              • portzi
                • May 2011
                • 75
                Hi Mike thanks for the swift reply. I will have a look tomorrow evening. Where is the number usually located?
                Mark
                • BosnianS2
                  • Apr 2005
                  • 322
                  Hello Friends,
                  I just got email from Audi dealer after looooong wait, that this caliper slider repair set -8A0698430 upper fronts stock disc 304mm- is NLA.
                  Does anybody know where I can get one of these so I can complete my caliper rebuild?
                  Thanks in advance
                  • rynaqui
                    • Mar 2012
                    • 2752
                    • Country: Malta
                    Hello Friends,
                    Thanks in advance
                    Being a brembo caliper, for my 996.351.425/6 calipers, I got all sorts of service parts from:
                    We provide high-class refurbishing services to all Brembo brake calipers. We specialize in replacement Brembo parts and brake upgrades for high-powered cars. Addiction Motorsport Ltd has been providing a unique, quality service to automotive enthusiasts throughout UK and Europe.
                    Maybe they can help you out?
                    1996 S2 ABY Silver
                    • BosnianS2
                      • Apr 2005
                      • 322
                      Ok, i will try them out. thanks for the info
