Brake fluid quantity
  • Brake fluid quantity
    How much do we need for a full reflush?
    And since we are at it, I'm.looking at a good dot 4 one. Which do you recommend?
    ATE Super Blue from ECP.
    Get 2 litres but you might only need 1 and can take the other 1L back.
      Oh only 1 litre? That's not bad
        According to mikes site 500ml/caliper, 250ml from brake master cylinder if bleed nipple fitted.
        http://www.s2-audi.co.uk/tech_articl...e_bleeding.htm
        I normally just do it until no bubbles/runs clear. Using different colours makes it easy, pretty obvious with new/old fluid if the old fluid is old or has been cooked.
        Sold ABY-stock
          Many thanks. I have ordered enough to keep as spare. Went for the castrol dot 4 react
