fitting New abs pump & best brake fluid?
  • MGaz
    • Feb 2008
    • 698
    Need to fit the new abs pump on A6 c4 quattro.. Any advice on fitting and bleeding the system?
    Also, what would be the best brake fluid to use? DOT 4 SUPER? or DOT 5.1?
    I understand dot 4 SUPER is better for boiling point, but dot 5.1 has better viscousity witch is better for ABS and traction control systems. So would that apply to the EDL system?
    C4 A6 AEL avant quattro: daily
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • MGaz
    • Feb 2008
    • 698
    I've never bled a brake system before, but my dad has. So he's going to help me with it.
    Just wondering if there are any special considerations to take on board when changing the abs pump? or i just bolt the New pump up and bleed the system as normal?
    Cheers in advance.
    Schrick 272 cam
    ITG filter
    • ManiacuV6
      • Dec 2009
      • 458
      • Country: Romania
      The simple way is to pressure the reservoir with not more than 1 bar and after that to open the bleed bolts!
      Audi S4 2.2T 5 spd 1992 for parts
      AUDI A4 1.9TDI daily use
      Audi 80 Quattro 2.0 16V (ACE) aka Competition
        Yup, pressure bleeders are the best way to go - so easy
