urS6 - Front Brake Hard Lines - Query
    Can anyone confirm the LHS & RHS part numbers for the short run of metal pipe that runs from the urS6 brake caliper to the rubber flexible brake hose ?
    Are they still available as a pre formed part ready to fit, or does the dealer sell you a length of brake and it has to be flared and bent into shape ?
    Same query applies to the two respective runs of hard brake lines from the "inner" end of the flexible brake houses under the front wheel arches running back to the ABS module in the engine bay ?
    Any comments / information appreciated.
    Thanks.
    Looks like 4A0611721 left (192 mm), 4A0611722 right (192 mm)
