Can anyone tell me the thread size and dimensions of the standard porsche caliper bolts please? (Boxter S etc)
quick question
Tags: None
This is from the "recipe" to add Big Reds or GTS Blacks to a NAmerican UrS4/S6 with RS2 brackets:
"Also:
Bolts, long (caliper to bracket, x4)
999.067.041.09 (Porsche Part Number)
Bolt, short (Strut to bracket, x4)
N 100 880 03
Bolt size is: M12x1.25x25mm "
Searching on 999.067.041.09 yields info like:
" Part 999.067.041.09 and they should be around $3 each. Use a M12x1.5 thread chaser to clean the threads on the wheel carriers."
And, perhaps more importantly, this link to £2.46 (VAT in) caliper bolts in the UK:
94 UrS4 V8 6 spd manual avant -
yep Dave once again is correct....how many do you need as I've got some spare new ones kicking about....I had to get longer bolts for the bigger caliperComment
