My S2 has been layed up now from May. I drove it last night for the first time since that. The brakes seemed very spongey and the ABS light stayed on. This evening I hooked the car up to VAG-COM but I'm getting no response from controller on the ABS Unit. I can scan the engine and Airbag systems fine. I'm fairly sure that any time I ran a scan in the past that the ABS unit was fine. I have checked fuse 31 which was fine but I replaced anyway, also took the plastic over off the ABS pump and replaced both relays. Started the car and the ABS light went out but every time after that it stayed on. Still cant communicate. I can hear a ticking sound when I try which seems to be coming from behind the stereo area.
My wife has told me that the last time she drove it back in May that the ABS light came on after a couple of miles, stopping and restarting put it out again for another couple.
Anyone any ideas where to start with it?
Sorry, nearly forgot, car is a 95 ABY avant.
Cheers.
Cheers.
