Can't lock rear wheels on brake tester
  • Can't lock rear wheels on brake tester
    I understand there is no adjustable bias on these cars (Coupe 10v in question).
    On the brake tester, both rear wheels have almost no effect.
    Both rear calipers are changed and there is no air in the system.
    Any ideas?
    If at first you don't succeed, destroy all evidence that you tried.
    -CQ 3b "S2".
    IS quite possible that you have a problem with the brake pump. Check also both sliders for every rear caliper.
    Audi S4 2.2T 5 spd 1992 for parts
    AUDI A4 1.9TDI daily use
    Audi 80 Quattro 2.0 16V (ACE) aka Competition
      Does it have a rear ride height system that adjusts the brake bias when you put heavy loads in the boot ?
        Head, nail, on ?
        BUT I DON'T WANT A NEW CAR!
        1995 S2 Avant, Volcano Black
          I wish it did, Quattro cars (typ89) does not have a load-valve as far as i know
          -CQ 3b "S2".
            Is there not a brake balance valve on the bottom of the master cylinder?
            You can just see it here
              Well, all that does is control pressure to the rear with pressure to the front. Not adjustable in any way. Perhaps worth a try?
              -CQ 3b "S2".
                I don't think its adjustable but it could just be knackered. Could probably replace with adjustable one though.
                  bypass it and if it doesnt lock up then theres a major issue with the master cylinder!
                  1993 URS4 Avant Emerald Green 350+bhp
                  1991 Ford Sierra Sapphire 4x4 in Magenta
                  BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
                    How do i bypass it? Just replace it with a T-joint?
                    -CQ 3b "S2".
