Hello,
I have front and rear Big Blacks from Porsche 928 GTS (similar to Big Reds from 993tt). My question is what is a maximum size of front and rear rotors to fit these calipers to 17" rims? Stock rotors are 322mm but it seems there is some space left between a caliper and a rim. I want to fill that space and to install as much bigger rotors as possible.
The other question is what manufacturer and type of rotor do you suggest to use? I mean best for the price/heat dessimination criteria?
