Just looking in to my ultimate brake setup to fit under Avus 16s and unfortunately, 996s and the rear vented 323s are a no-go. The 314s fit perfectly but are front vented, although there are holes in the hat, so they don't lend themselves as well to brake cooling ducts from the rear of the disc... There is a 321mm A6 disc but again, that's front vented
Some research indicates that with a 10mm hub spacer, I can run something in the region of 319-320mm discs, so was a considering turning down some 323mm but I'm concerned about the balance of the disc, as this is normally done on the OD.
Other option is custom 2 piece but that's a bit exotic...
