if you find the wheels that sute your car its ok... but if your putting the brakes what power are you going to?
becouse the most peoplea chang to 5hole is the awailability of the wheels
There are plenty 17" wheels out there from Ford, Citroen etc and remember when you get the RS discs ( 324mm ) that you will need to bore out not only the centre but the wheel nut holes too as they are just too small....
