B7 Disc, 300x22 vented - 8E0 615 601R (2-off)
A8/S8 carrier - 4D0 615 425C (2-off)
Calipers from RR quattro or UrS4/S6 - 447 615 423 and 447 615 424
S8 pads for those 280mm discs - 1J0 698 451L
50mm long caliper carrier bolts - N101 815 02 (4-off)... Shortened to ~35mm for the task
Also recommended along the way is new brake lines and clips for handbrake...
S2 Coupe rear hose - 893 611 775 (2-off)
Brake union clip clamps - 4D0 611 715B (2-off)
Handbrake cable lock clip - N900 527 02 (2-off)
If so I used the stock handbrake cables and they fitted fine under stock 16" avus wheels.
