HP2's nearly scared the sh*it out of me
  • HP2's nearly scared the sh*it out of me
    A couple of days ago I noticed that my brakes have gotten quite soft/spongy and that I had excessive pedal travel. I decided to simulate some emergency braking and then I got a bit scared….. The pedal went to the fu*king floor and the braking force wasn’t enough to make the abs work – not even on wet roads!
    Then I tried bleeding the calipers because I thought that maybe there were some air pockets in the calipers, but then this caught my eye (photo) - and the same has hapend to the right side too
    So, if you have HP2's and you suddenly experience spongy brakes, then please check your pads!
    1993 AAN UrS4 Sedan
    Pad material separated from the backing plate going by the picture.
    Is the car used regularly?
    Sold ABY-stock
      Yes it is
      1993 AAN UrS4 Sedan
        Weird, I have seen that on pads I left in a damp garage, and on cars I have bought that sat for ages.
        Cheap pads?
        Sold ABY-stock
          Cheap pads?
          I think they are genuine audi pads, don't know how old they are but at least 3 years old... I already ordered new ATE pads in germany - now I'm just waiting for the f***ing DHL-guy. Hehe
          1993 AAN UrS4 Sedan
            Thanks for sharing, with photos, and reminding us all of this potential issue.
              Hp2
              Being in the mechanic game for over 40years I must say this those calipers look a bit grotty to me or should I say a lack of maintenance mine are not perfect but look a lot better than those
                Just because the calipers look rusty it doesn't necessarily mean that there's something wrong. I can assure you that they perform as they should
                1993 AAN UrS4 Sedan
                  Hp2
                  Brakes are Brakes and your life depends on it , as an ex vehicle examiner if your car had been involved in an accident the first thing I would look at is first the brakes then that suspect brake pad and if that was found to be instrumental in the cause of the accident then I am afraid you would have some explaining to do to the courts
                    I know! That's why I don't drive it till I got new pads....
                    1993 AAN UrS4 Sedan
                      Really?? They look like they've been at the bottom of the sea for a few years, I'd get them stripped and overhauled if I were you.
                        I did that last year
                        1993 AAN UrS4 Sedan
                          Or you could upgrade to some bigger brakes in the same condition
                          Tonks4x4 - The Land Rover Specialist
                          Audi Nut!!!
                            They probably look like my calipers. I had a similar thing happen on G60 calipers, so not just related to HP2's. Luckilly I was changing discs and pads, when I took one of the pads out, the friction material had started separating from the metal backing.
                            1996 Audi S6 Avant.
                            1994 80 TDI - Daily Driver
                            • #15
                              Hahaha.. I'm afraid that such an extreme high performance brake upgrade will catch the MOT-guys attention
                              The picture reminds me of an old joke: How do you make a Volvo go faster?? - Simply by raising the plough
                              1993 AAN UrS4 Sedan
