Don't know if anyone ever done this on UrS6?
Front 314X30mm
Rear 269X20mm
Both are almost identical on the overall height approx. 59.4-59.5mm
The rotor is planning to be clamping with Rear 4pistons caliper from Cayenne S 4.5L
Calipers.I already have 6pistons caliper on the front axle.it's the good time
to match another 4pistons on the rear.I have the spare rear hub carrier.I'll be
tested fitting and see what's going on whether requires the custom bracket or
better grind off the overall Dia. of the disc down to bolt the caliper right up
on the hub carrier.the Calipers can be clamping on the 30mm thickness flawlessly
since the stock rear cayenne disc has 28mm on the thickness.
Front 314X30mm
Rear 269X20mm
